S350L
- Jan 1, 2016
- Mercedes
Hi gang,
my near side xenon headlight is flickering quite a bit so I thought I’d change it. I’ve brought the correct D1s replacement bulbs , so I thought I’d proceed.
Disconnected the battery, disconnected the screen wash bottle, and removed the cover behind the bulb that I’d like to change. This is where I’m stuck, as I was expecting to see a clip, holding the original bulb n place, however, there was no clip!!!
Does the bulb pull out or does it twist.
thank you
thank you
