Hi All
Hopefully someone can help me out on here please?
So I have a w639 Vito 2008 and the fuse box is in the engine bay, in a big square box.
I needed to replace the box blower/ cooler today as it was getting very loud (what a wonderful job that is.... Not)
While I had all of the contents of the box out, I noticed that there is a white connector with a single wire not plugged into the underside of the main fuse board.
I'll find find a photo online of the part and make it for you. I believe it has an 18 or I8 marked on the socket where it lives.
Basically the wiring in that compartment has been messed around a lot over its life and looks a little like a birds nest, I'm not sure I should plug in a plug that has been left out by someone without knowing what it does.
Maybe its an alarm thing as that looks like its not working anymore (not since I have owned it) or maybe its a wire that has failed in the past and someone has replaced it elsewhere in the line.
So anyone know what the wire is for?
While I'm asking can anyone tell me where the gearbox control module is meant to live as it has just been slung on top of the birds nest. I assume it has a home?
Thanks for any help given and I hope to have a fuse box I can be proud of
Si
Si
