wanted comfort relay for w124
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
PM me if you have one at a good price (not sure if mine is bad but wanted to find out cheaply)
thanks
derek
this is the photo of my actual one i have now:
202 820 09 26
i am assuming it may be faulty as my drivers auto-down window has never worked, the passenger auto-down used to work but no longer does and recently i've noticed if i keep the key turned in the lock to auto-close all windows/sunroof this no longer works when it used to....
i sold the one i had with the same part number 2 weeks ago, but i have just got a T300D, i will check on that tomorrow, dave
i have one available if your still looking
£25 incl delivery
I managed to get one, but thanks anyway. Turns out it didnt make any difference - i still dont have the bits i need fixed, fixed, so i suspect the relay wasnt at fault after all
try the switch swap and then open door and check motor is working, there is a clever way playing with wires to work in bypass.
it now can only motor of the switch being driver i would try the switch first.
if coupe or convertible replacing mechanism is job, motor not so sure
