mercman1969
- May 18, 2005
W163 on a 52 plate
I am still getting an intermittant fault regarding kickdown
it appears to be when under load....on hills - even very shallow ones
at times even when depressing the switch under the pedal the car simply doesnt kickdown
sometimes if you back right off the throttle and then try again it will kickdown....other times it wont
my thoughts are
Throttle Position?
Gearbox fault?
What would cause such.....would a faulty MAF cause this?
my thoughts are
Throttle Position?
Gearbox fault?
