Something wrong here, I use the same one and it’s very easy to apply...
You and everyone else who seems to have used it. It comes as a hard wax. Not a ‘paste’ as described. Is that correct?
Yeah that is how mine looks, maybe you are putting too much on?
Did you prep the surface first?? Or applied straight after washing? Cos thats what I did.
It was a very thin layer. It reminded me of back in the days when I first used Zymol carnauba wax. Put it this way, it was so much work I met my step goals on the Garmin in that hour. LOL
Straight after washing! Maybe it is to do with temp because I did it in summer
What are you using to apply it and how long are you leaving it on for?
I usually use a sponge pad and go over small areas in a light circular movement. I also tend to do 2 panels at a time. For example, start with a rear wing, then the rear door. By the time I've coated the door then the wing is ready for buffing then, once that's done, buff the door and move on to the next couple of panels.
I use the sponge provided. Followed the instructions as it states to wet the sponge. I leave it on for about 5 mins. It has clearly dried. Then when I went to ‘buff it off’ i almost lost my right arm...
I have this product along with HD wax plus others.
I suspect it could be due to the weather, there is a lot of damp in the air recently even when using a garage, unless it’s heated of course.
Applying and buffing off wax and or polish at this time of year is problematic even on dry days.
I cannot imagine the product being faulty.
Robin
