rich1068
And what tangible benefits does the massive increase give?
A quiet life.
You are not a million miles from us and all our fibre phone cabling is underground (under the roadside footpath) then copper under the front garden to a point well inside the house. They are overcoming those problems on the other side of our estate by planting new wooden telephone poles in the pavement and running overhead fibre directly to the gutter area of the house.I have TalkTalk 65 fibre....they guarantee 50 minimum.....whenever I check I'm getting around 57 to 60....so that's fair enough. More than enough for me to watch HD TV and my son to game on Fortnite in Hi Res at the same time with my wife on her phone facebooking her friends. We used to have 2 meg until about a year ago as there was no fibre in our local exchange and all the phone cabling is underground (rather than on poles) and old and that was about the limit....so much better now......but not as much faster in actual use than you might think. TV used to work fine on two mb (non HD) even though it was supposed to need 5 minimum.
French prices make Brits gulp but you are where you are. Only other people living in France can throw light on that.
For private use, any speed faster than 50 mb is normally irrelevant. Is your provider offering a slower speed through the cable? If the most you want to do is watch video feeds, 50's plenty.
Your router problem is a red herring. You'll get a new Super Duper router with the connection, your old one won't be up to the job. The new one will offer faster protocols. Just ask your neighbour what happens with their router and speed loss through their walls. Beyond their recommended fast router, there's also an option of Mesh WIFI, but worry about that if, as and when.
Specifically answering your question, people don't "split" a fibre cable, assuming it's FTTH or FTTP (same thing: end to end fibre). If you want two connections, you get two fibre connections. But see above.
It's only with FTTC (Fibre to the (Roadside) Cabinet) that you might do multiple copper connections between your home and the "Cabinet" down the road. But from what you've said about that 850mb speed and price, I'm sure you've been offered FTTH.
Don't understand your passing comment about cabling running overground from the roadside: do you mean risk of damage?
It's five decades since I debugged some TC code for IBM Hursley, so I've seen TC speeds improve a bit. But the folk on here have all kinds of arcane knowledge.
Super high speeds are all well and good but ultimately it's the website bandwidth you're visiting that determines the download speed, surely?
A friend lives in an old stone French farmhouse in Limousin. He's got the really thick walls, and uses two separate routers linked by wire to ensure a signal throughout the property - you just log on to both, and your phone or tablet switches between the two as you move from room to room. He's a retired electronic engineer, so I suspect he knows more about these things than I do!I just wondered, in my ignorance, if it was a simple job to split the signal where it enters the property and put in an extra router. I have a friend who installs wifi extensions for a living, so will see what he suggests.
Ah, that puts it more in context. Apologies, I jumped to the wrong conclusion that your connection would be more primitive.Thanks - we're signed up to the "up to 1 Gb" package which we've never attained and the 870 Mb is the SpeedTest figure which matches the router one.
Yes, we have a super-duper new router but the property is quite rambling, being 2 knocked into 1 and part of the new area is still bereft after several thick stone walls. The neighbour has a much smaller property. We can get 2 cables in, but they want to charge us for 2 lines!
The overground cables - especially the 'leccy - have a habit of cutting out in the high winds we sometimes get here. The broadband posts are a mixture of new and old, so crossed fingers!
I agree that the speeds we're getting sound impressive but, as you say, are probably excessive for what we need. I remember - not too long ago - that we were happy to have 2 Mb which was the benchmark for online tv.
That’s typical of the UK. London has had pathetic internet for years. We had to have a dedicated leased line at work, at £300 plus pm, to get decent speeds.I am currently in the South of Italy, where most residential areas had FTTP for nearly 10 years now (it's just being rolled-out in London as we speak....):
I would get these. They make a huge difference to WiFi stability and performance. You can set them up to have the same WiFi network id and password as a meshed WiFi network and should solve many of your thick wall problems.Thanks - we're signed up to the "up to 1 Gb" package which we've never attained and the 870 Mb is the SpeedTest figure which matches the router one.
