Higher bandwidths don't normally make a difference to day-to-day browsing, but they are very useful when downloading large chunks of data, be it for fun (40+ gb of maps update) or for work (software updates etc).
Do you need a Mercedes!?We are on EE fibre (copper to the exchange) and typically get 44-74Mbps down and 18Mbps up.
They have put fibre in our street, so full-fibre is available for us but we currently have no need for a 300Mbps connection.
Ah, that puts it more in context. Apologies, I jumped to the wrong conclusion that your connection would be more primitive.
Your issue is internal distribution rather than line speed.
Solution is to look at improving wifi distribution or creating a distribution post router.
I’d talk to the provider about their recommendations for wifi networking, or call in a local WiFi techie.
See Fabes’ comments about creating a Nest 6 WiFi network. That might work alone, or could work with a wired connection between two ends of the house.
Running in a second “motorway” because of a blockage at a run-off seems unnecessary, but I know why it’s tempting.
Ps You lucky, lucky man….
(The property, not the cable)
"Quite"Do you need a Mercedes!?![]()
You're quite right. Try explaining to a 10yo that the reason Roblox is slow is nothing to do with "our" internet and the fact it might have been quicker at a friend's house is nothing to do with their BT/Sky/whoever connection but sheer luck.
To answer your earlier question in a little more detail, I have to download large files regularly, my wife works from home and manages a national team via Zoom/Teams, we have a 15yo, 12yo and 10yo in the house and we stream 4k UHD to more than one screen via Sky Stream. Full fibre is absolutely rock steady and coupled with the very reliable Zen Internet being the provider only costs a little more than their FTTC.
I would get these. They make a huge difference to WiFi stability and performance. You can set them up to have the same WiFi network id and password as a meshed WiFi network and should solve many of your thick wall problems.
You can wire them together using standard Ethernet cables if they still don't penetrate the walls.
Yes, an ethernet cable to second router will do the job, but it is worth having a sniff around wifi 6 to see if that broadcast method can resolve the issue without the cable. There are lots of reviews and sources - you'll be limited to what you can get from FNAC and Amazon.frThanks for that - seems like another router linked to the first, is the solution. I'll have a word with my techie friend.
The highlighted bit above ..... not as attractive since the recent energy price increases! The stone walls make good radiators, but the draughts find the smallest cracks ... and there are many!
Sorry - google TP-Link they do lots of solutions. I have the M4 whole house mesh network. You should be able to buy them from Darty or other electrical retailer.Thanks - can't access that page directly (even with fibre!), so will browse their wifi router/repeater pages.
Agreed - but it's not always possible. The speed and jitter (which is essentially how laggy the response is and crucial for phone over WiFi) on a decent mesh setup is more than good enough for most applications that you're likely to encounter in a normal domestic setting.Mesh is OK, but if you can run Cat5/Cat6 from the router to the APs, that's always going to be the better solution.
Silly question…Do you need a Mercedes!?![]()
Silly question…![]()
In my case, clearly not as I don’t have one (AMG Line isn’t an AMG)Yes, but do you need an AMG...?
