Can anyone explain the significance of the air flow sensor in the general workings?
For example, the output from the sensor goes up with air flow. This is then fed to the computer, which presumably adjusts the fuelling dependent on the pedal sensor as well.
So if the air sensor starts to read low, then there is more air going into the engine than the computer knows about, so presumably it reduces the fuelling thus resulting in a loss of power.
But if you tread harder on the accelerator, presumably the computer injects a bit more fuel to cause more air to be pulled in, but the sensor always says that the air flow is not increasing, so does the computer then add more fuel to compensate? This would result in overfuelling?
So does the car run rich or lean, or does it depend?
(I suspect my air sensor is failing as I get a loss of power, but I'm wondering if this would also result in poor fuel economy as well)
Not a well stated question, but I hope you get my drift!
Nick
PS Mines a diesel
Nick
PS Mines a diesel
