Convinced?
Can you explain what we're looking at
it was responsible for a 3.5 degree increase in outside temperatures
Ok I think I understand the mapping. Now I have read in lots of articles about updating ECU software or is this the same as remapping?Basic description of re-mapping.
The ECU has a lot of data in it on how to control fuel input according to different conditions. It measures ambient temperature, engine temperature, air inlet temperature, air inlet volume, manifold/boost pressure, the composition of exhaust gases, engine knock level, speed, throttle position, etc etc (depending on system).
It has a giant table/database type thing which basically tells it how much fuel to give under each of these conditions. This is known as the 'map'.
So, a very simplified way to explain it, every tiny fraction of a second, the ecu thinks ''boost pressure is 0.5, air flow is 2.1, throttle position is 43%'' and then it looks up in it's giant database thing to tell it the correct fuel level for those parameters. It does that hundreds of times every second.
Manufacturers spend millions developing the correct map for any given engine, however then other 3rd party companies come along and develop new maps, this is called re-mapping.
Re-mapping has two uses:
One use is to change the engine's operating parameters to suite other modifications. For example, if you fit a high performance exhaust, high performance air cleaner, port the head, use bigger valves and fit a bigger turbo, the stock map will not apply enough fuel, since the engine will have more breathing capacity than the ECU is programmed for. Similarly, if you increase injector size, it will over-fuel, since the stock ECU will think it's using stock injectors, and bigger injectors flow more fuel for a given pulse.
Another much more common use for remapping is trying to squeeze more power out of a stock engine without changing anything apart from the map. This is done all the time by almost everybody, but comes with downsides.
Engine manufacturers spend a loooot of money developing maps, and the maps they come up with is usually a perfect compromise between drivability, economy performance and reliability. With any kind of car tuning, you can only pick two out of the three: Economy, power, reliability. You can never have all 3. So usually remapping a stock engine increases something but decreases something else. So the chances are, when you increase power output, you will defiantly hurt economy or reliability, since there is no such thing as free stuff.
You can have big power gains from remaps, but the engine will drink fuel and wear out much quicker.
The only exception is cars which got released after a really rushed production run, and there was so much pressure to bring the car to the sales floor that the manufacturer havn't finished developing decent maps for it. In those cases, re-mapping can genuinely improve everything.
But, unfortunately, car manufacturers aint stupid usually, its pretty rare for them to be stupid, and also there is no such thing as a free lunch.
Fair summary, Somebody.
The only issue I'd like to add a little to is question the assumption that the OEM maps are generally optimum.
They are of course a 'one size fits all' map and this will not be optimum for every user.
However the main problem is that the maps are not optimum, but are designed to get max mpg and less CO2 readings on the official tests.
This does not mean a perfect compromise as suggested. The truth is that OEM maps are not the best balance between power, economy, and reliability in real world use.
A shot in the dark here - but I'm guessing you've had yours remapped.Fair summary, Somebody.
I disagree.
Are CO2 emissions independently tested for every model-type ?From what I know of CO2/MPG tests, most producers carry them out with custom maps - not the production maps used for the cars on sale...
