What is tthe torque on the manifold's bolts?
Olivier
Edinburgh
E300 TD
Hello,
Anyone as the torque value for the 16 bolts that hold the manifold into the head on the E300TD 1997?
Thank you.
Olivier
Cheers Ian.
Its little... I probably used a bit more force then this doing it without the torque wrench...
Olivier
Oh.
I feel a bit better now :)
Cheers.
Olivier
be careful with those bolts, one of mine snapped quite easily. luckily removed it using a pair of pliers.
Got different bolts, I can't stand torx as you need extra tools( the bits anyway) and its too easy to worn the inside which make it a nightmare to remove. I quess they are special alloy not to damage the head threat?
I was looking for some allen / socket bolts but could only found hex head, I am still trully happy with this. Easy in and out with a good grip :)
