wheel alignment
fnkhan68
London
1993 Mercedes 320e and 2000 BMW E39 523i
went to get the tracking done on my car today but was told that the track rod ends have seized so cannot been done. how do i get them to unseize as the tracking is out on my car. the tyre fitter told me this was a common problem on older mercs and that the track rod ends are hollow which means putting pressure to free them might cause them to break or bend. thoughts please anyone?
I had a similar problem on my 190, I think the only solution to get your track rods replaced. They are not that expensive and are around £20 each
Yep I'd replace them, after all, you are/were going to get it adjusted anyway, could be worse timing :)
Will
is it an expensive job labour wise to get these changed?
