Hi everyone,
This is my first post on the forum. I've been lucky enough to have taken on a 1980 W123 saloon. I don't have too many details as yet but as far as I know it's a 200 automatic petrol.
The car's been sat a few years in a dry garage so I want to get a few servicing parts ordered before I pick up the car so I'm ready to get to work straight away. Front and rear discs and pads will be ordered shortly along with oil, fuel and air filters and spark plugs. I think I will also do a coolant flush whilst I'm at it along with an ATF change.
A few questions:
1.Is there a filter in the gearbox/sump? Where can order one? Eurocarparts don't seem to do it.
2. What fluids are recommended for each of the above? I don't have a service/owner's manual.
Engine oil
ATF
Brake fluid
Coolant
3. Should I remove the old fuel (how)? Apparently these were designed to run on leaded petrol. What do people use now? Do you use a lead additive, what is it and how often?
4. Any other suggestions for things that would need looking at? I have a new battery to go in.
Any help/advice would be appreciated.
A few questions:
Engine oil
ATF
Brake fluid
Coolant
