Whirring noise from under dashboard
amwebby
Thorpe Bay
CL500
Today I noticed, for the first time, a whirring noise from under the dash on the drivers side. Anyone have any idea what it is? Should I be worried?
When does it happen?
After doors unlocked? Engine running? After turning off?
There is a very small fan mounted in the Heater control panel used to monitor cabin temperature. Are you its not coming from there ?
It is happening with the ignition switch in the II position or with the engine running. I can hear it very clearly if I stick my head in the driver's footwell but it could be coming from the centre. I turned the air conditioning off and it was still there.
My W210 does that - thought I saw mentioned somewhere there is a rotor/fan in the comand unit?
Today I noticed, for the first time, a whirring noise from under the dash on the drivers side. Should I be worried?
Yes, because it's the tracker your Wife had fitted yesterday..;)
Cooling fan for something, I would guess.
Hardly the same vehicle ;) but this is noticeable on our Vito - the fan for the electronics (somewhere behind the dash) runs for some time after switching off the ignition.
I'm sure it is a cooling fan for something, possibly with worn bearings? It only comes on when the ignition is on and not straight away. Yesterday I drove into London, after 45 miles it suddenly came on. I then parked and had a series of meetings, lasting about 4 hours in total. When I came back to the car the noise started immediately upon starting th car.
Update: 04 October 2009
The whirring noise has stopped and my easy exit feature, which had not been working for over a year, has suddenly kicked into play. It would seem the two are related. I'll keep an eye on it and report back.
