Will this amp - Sony XM-N502 Stereo Power Amplifier' be compatible my 22 Plate A class?
Benz000
UK
A250
Anyone know if this is compatible for my car before I buy it?
Only 1 left on the site
I don't expect that many people on the forum will have thought about modifying the audio on a '22 A Class so you might get more reponses on a dedicated car audio forum or by talking to a couple of professionals. As your car is presumably still under warranty any changes you make would ideally be done by a pro anyway, as a simple mistake in wiring up an amp has the potential to get four-figures expensive quite fast.
Thank you for your response
By a pro' do you mean I should get a Mercedes dealership garage, or approved Mercedes garage to install the amp?
As opposed to just a car audio place?
Thanks again
I can't imagine that a Mercedes dealership would want to install aftermarket equipment. A professional car audio installer with a good reputation would be the way to go so that they have the expertese to remove and refit interior trim properly and determine the correct wiring to connect in to, and if they mess anything up you should be able to rely on their professionalism to make it right. Plus you can have a conversation with them about what you want to achieve from your audio upgrade as they may suggest alternative solutions (upgraded speakers, for example).
Be aware that hacking into a 2022 vehicles wiring may (will) invalidate any warranty claims you may have , if the issue is with anything electrical.
K
There are 3 different audio systems for a A class. (a) Basic, (b) one with an extra amp and subwoofer / centre speaker (c) Burmeister. I assume you dont have (c) , but if you have (b) it requires lots of consideration when adding an amp for the fronts ..
