Will this stereo fit?
I don't know the answer, but I was just wondering what would be the benefit of this unit over the Audio 20 unit you probably have now? the iPod connector and USB port? I think these can be arranged for the Audio 20 unit, but best ask members Alfie and Richard, this is their website:
Welcome to www.comand.co.uk
They are based in Lightwater and can supply re-fitted COMAND units as well as alternative (non-MB) entertainment systems.
thanks but they are very expensive.
i want something to take USB so the one i put there is ideal.
im not keen on the current unit tbh. it feels dated and doesnt do what i want it to do .
cheers
It'll fit. You just need one of these:
HTH ;)
Lol are you saying it won't then??! I just presumed it will cos you have a bug gap under current stereo so once removed there will be a big space.,.,?!?!?
Mercupgrades.com has a headunit removal guide.
Search the electronics section of the forum, plenty of past threads about aftermarket units in a W203. From what you have posted I take it you have a pre facelift with audio 10. You will obviously need a fascia adapter and antenna adapter. Car already has iso connections.
Not sure wether it's audio 10 or something else. How do I tell?
Will I need a fascia adapter with one of these larger head units? Will the current antenna not go into back of new head unit?
Post a photo...it takes the guess work out.
Or he could simply google audio 10 and have a look at a picture off one ......
But a photo of his dash will allow me to assess whether he could fit a double Din unit by removing other trim...the audio 10 is single Din.
RIGHT
its audio 10
does this mean ill have to get one of the smaller stereos?
cheers
Cheers pal, with one of these adapters will the larger stereo fit into my vehicle ok?
im unsure so want some heads up before i spunk some dosh
Your existing radio is single Din. You want to put in a double DIN...the adapter will do that.
thanks chap.
there is no price on that link. is this ebay item the same kind of thing? will this fit my car?
MERCEDES C CLASS <2004 Double DIN Fascia Kit CT23MB02A | eBay
sorry for the n00b questions.
once i have this, i am free to buy a double din bigger head unit correct?
i will not fit myself, i will get some one like halfords or car audio shop to fit.
cheers:thumb:
cheers just couple more Qs..
so all i need is that kit for my kompressor coupe 53 plate? and a double dim player?
NOTHING else? i am getting some one to fit so want to make sure i haver everything.
how much would halfords charge to fit it if i didnt buy from them?
also is there such things as mobile audio fitters around? how much roughly would they charge to fit this kind of job?
cheers
guys,. sorry to ask this again i just would like confirmation of the above so that i can go ahead and order.
i understand these are n00b questions but i really am not too great with cars, cheers :(
Are you aware you are liable to loose the steering wheel button control of the radio etc with changing the unit - unless you are lucky enough to get something that takes an adaptor to make them work? Also be careful who you choose to fit the unit - pulling the radio on a w203 means removing most of the centre console! I had a specialist ICE firm install my CD changer (which also involved pulling the radio to make the connections on the back) and got off very cheaply at £50.
If I can find the link, there's a very good post on a US site showing what's involved in changing the radio on a W203.
Edit - it's http://forums.mbworld.org/forums/showthread.php?s=&threadid=13302
Edit - it's DIY: Audio 10 Install Pics / W203 ('01-'04) Center Console Removal Instructions - MBWorld.org Forums
yeah i realise its quite involved, annoying tbf.
i understand the steering wheel volume button will not work..not end of world i supose.
would halfords even know how to fit the stereo?
any recomended ice firms in bristol area?
