hi guys - the window assembly broke on my w208 ( x reg) so rather than drilling it out sourcing and refitting one i managed to get another complete door and swopped them instead, the swop went well except for the window ( drivers by the way) will go to the top but will then drop 2" , ive tried the "holding down & up the switch" for a period of time so as to reset it. its the type that should drop and rise slightly when opening and closing the door ! i should add that ive changed the window switches panel as well just incase it was a faulty switch. i dont really want to get another window regulator/lifter unless i know its faulty because it was all working fine before the lifting assembly
broke !
oh and what is the yellow/green plastic tube that connects on to the grey nozzle ?
i should add that ive tried disconnecting the battery for 30 minutes or so hoping for a reset !
broke !
