window jets
pills12
kettering
clk 230 w208
can anyone tell me how to remove the washer jets from my w208 need to clean as blocked and needle wont clear problem
you need to push them out from underneath. its a sort of clip. once you remove the wahser pipe and look up with a torch all should become clear.
there may be a plastic cover stopping you from seeing the jets you may have to remove this first, but otherwise do as SilverSaloon says.
K
pipes jus pull off, and electrics are conected using connectors jus push the clips in and pull off
K
When you push the square plastic to release the whole cover & jet be careful not to lose a small plastic wedge that goes into one of the plastic clips to keep it extended and in tight in place when in the bonnet. Nearly lost mine.
