yeh, i was found this diagram but i had doubts about site of relays 5 and 8, if not is this there is possibility to control and verify operating condition of this relay or it should be replaced straightforwardly?
Without an internal circuit diagram and an understanding of how it operates its going to be difficult to test. Its called a "timer" relay so I guess the internal timer circuit is not switching off after the appropriate time and the glow plugs remain on. The simple solution is direct replacement. Its about £50 plus vat plus carriage from here. http://www.mercedes-benz-parts.co.uk/home/
Hi all,
Yesterday i was found the relay of pre-heating it's located below the container of glass water, so it's like a black box with a big connector with 5 pins (5 plugs) and a small one with only 2 pins (the witness in panel inside the car).
I was disconnected the small one and the led still lit all time.
I dont know if i can do something to repar this relay cause i m electonicien but without diagrams it's like a MI 4
Where can i find one please?
The Mercedes circuit diagrams show it to be a solid state device not a conventional relay with contacts coil etc so probably impossible to field repair.
