X218 250 CLS 2013 Estate shooting brake
PJDPanda
Glasgow
X218
So changed rear Airmatic Bags - Pipes - new pump - new Valve block - new height sensors both sides. Keeps sagging at rear drivers? Then discovered the chap hadn't calibrated the drivers side Height sensor grr... working a treat....
They need to be calibrated. Also changed the Merc to Arnotts wow what a difference cost also only £500 inc delivery from Germany for the both. Don't buy the cheap ones as they will fail sooner than later.
if anyone needs the part numbers I can supply them
