Fredyflame
- Dec 3, 2013
- slk 230 year 2000
Rear washer fluid is not working properly. The pump makes the right noise but only small amount of fluid appears where the blade spindle comes through the glass.
Is there a separate container to the front, and if so where is it and how do I get to everything as I cannot see how the panel on the inside of the door comes off and I can't actually see where the fluid comes out to spray the glass ( no obvious hole to unblock)
Any help or photos would be great, thank you.
