18" tyre pressure
amolak
B200Turbo & V350
I have put 255 /45 /18" tyres on my car.
Pls can you tell me the correct tyre pressure in PSI, for 1-2 passengers.
Amo
1998 S280 W140 UK
Try checking the inside of the filler cap, it's the same for all wheel and tyre combinations AFAIK.
I had 18's on a previous S320. I was running 34 on the front and 36 on the back.
Hint of advice with 18 inch tyres is to check the pressure every few weeks and top up as required.
I have 225 45 17's on a C220D 1996 and I called tech services at Firestone and Toyo and they both stated to use original tyre pressures as details on fuel filler cap or a couple of psi higher max - not what I was expecting to hear, thought a lot higher, but still.
I phoned MB Technical Helpline and was told the same thing. I have 17" AMGs.
