190d Injectors and glowplugs
a1jatt
Calgary, Canada
1989 190D
I will be replacing injectors and glowplugs on 2.5 diesel this weekend. Is there anything that i should be carefull about???
Make sure you have new heat seal washers for the injectors and new leak off pipe as it will be perished.
Heat seal wahsers?? where about do they go? and i wont be able use the old pipe?? i was thinking i can just cut the ends off and reuse the rest?
The washers go under the injectors, that's what's causing the blowby anyway.
The pipe will be perished, just replace it it's cheap.
THanks man, apreciate it.
