johnlewis1964
- Aug 17, 2017
- 2008 C180 Kompressor.
Folks I have a black c180 2008 saloon should I go 19s or not any pics would be great.
What are the physics if the overall diameter of the wheel does not change? Just curious. I assume rim size goes up and side wall goes down. So speedo etc not affected!No , much physics against it with ride quality and efficency losses .
Plus our roads don't reflect their use .
Cars with massive rims and tiny brake disks look odd.
You will bite the end of your tongue off if you hit a pothole with 19’s
Totally don't agree.No one would design an ultra low profile wheel/tyre size combination on the basis of how it performed dynamically. Everything is against it in terms of extra unsprung weight and sufficient tyre sidewall to absorb shocks and protect the wheel/ suspension components. And that is before you even consider what it will do to the ride quality. There must be an optimum tyre profile size that is a reasonable balance between looks and performance but it isn't 19" wheels when the stock ones were 16".
The answer is simple - No if you care anything about how the car performs dynamically and yes if you care only how it looks to the exclusion of everything else.
Well if the op develops a lisp caused by the end of his tongue missing it’s not my faultTotally don't agree.
