Petrol Pete
Hardcore MB Enthusiast
A seaside car !..this get's better at every postthe car is in brighton, may pop over easter to check it, again as it so far i requested a vid and seems ok.
probably been there for short span of its life, i suspect 5+ owners, that could be anywhere. But i get what you saying, i will check the rust. Had mondeo from seaside and had more rust than my uncles tractor on the farm.A seaside car !..this get's better at every post
I know everybody here would suggest using mb star for check but do u reckon using delphi for scan could highlight any potential issues?
Unless they've been done since new, expect to spend £500 on having the engine mountings replaced straight away; they will be shot.
Terry Gates. He only uses genuine MB parts - £200. The exhaust has to be dropped to change the engine mountings on the W211 E55K and E500, and I'm assuming the CL will be the same.
If you are able to work on it yourself then you can rebuild the valve blocks for under £30 and the tandem pump itself for under £50.
Front struts can be a mission to replace because of the allen pin in the bottom arm. Rear struts are an hour each to replace maximum.
These cars are hard on the suspension components, I am pretty sure the noise in the video is one of the rear bushes (mine ate rear camber arm bushes but it was lowered!) these are not expensive to replace at all.
No ABC warnings on the dash is a good sign - just make sure it doesn’t sag overnight (easier said than done), even if it does then as I said, the valve blocks are easy and cheap to rebuild.
Thanks for advise. I am picking up mb star this week so will scan it thru. fingers crossed
