if i do not lower my car will there be rubbing issues?Howard
I can see in your picture where yours were rubbing.
Many of the 124's with 225's I've seen rub ever so slightly in the exact same spot.
See this thread ....
W124 AMG cars came with 225/45/17's from the f a c t o r y ...... , anyone that tells you that if you go bigger than 215/45/17 it will rub is dead wrong.
http://www.mbclub.co.uk/forums/electronics/70517-mercedes-230w-w124-abs-light-help-pls.html
Has the car been lowered?If not they`ll be fine.
thanks man.I wish that you are right.You'll be fine, 225/45/17 will fit lovely under there.
Look man:Many of us told you that 225/45 is the best way to go.If you like you can have 215/45 front and 225/45 or even better 235/45 for the rear.thanks man.I wish that you are right.
But if u had the choice between 215/45/17 and 225/45/17, which one u will choose?
thanks.
i wii definitely take 225/45/17 because i have TOTAL confidence in every body who help me to choose the best tire.Look man:Many of us told you that 225/45 is the best way to go.If you like you can have 215/45 front and 225/45 or even better 235/45 for the rear.
