After a few ideas really
M104 3.2 HFM engine from a 1993 S320 fitted to a 190E
(Sat) I drove it back from Devon after it had sat for about 3 years SORN.
The drive back was nothing short of perfect - not an ounce of trouble or even a hint that there might be something amiss.
(Sun) The following day I gave it a good clean and afterwards added something like 150 miles. The clean included checking plugs (so removing coil packs etc) as well as the MAF and crossover pipe.
(Mon)The following day I picked up the turbo kit and put a further 200 ish miles on the clock just driving. Nav tried it and it seemed OK
(Tue) - took it to work and to a job covering a few more miles (50ish)
(Wed) As above
(Thur) - - Went to start it to take it to work again - and it was very hesistant (see later), finally started after 15 mins - and all was good. On the return trip it was again hesitant but only for 10 seconds or so and then appeared normal again.
(Friday - went out early - and it was not going to start - took the astra and left it.
Came home after work and had another look and it displayed the following symptoms
1. Turn over on the key and after 6/7 seconds it will "catch" - run for 3/4 seconds and die. Any attempt to touch the throttle in this period will kill the engine dead. I checked every connection I had touched/moved to no avail
Then at around 9.00pm it just started and ran perfectly after an hour of me looking at it
Took it for a very local "spin" to put some life back in the battery and it was perfectly well behaved. Took a chance and stopped for a coffee as to this point I had assumed it was a cold start issue. - Well it wasn't and I was stranded outside the "Wild Bean" for 25 mins - then it started and drove very roughly all the way home it idles between 500-1200 rpm but doesnt die even in gear and stationary.
Sat
Took everything apart again , checked the engine harness very very carefully, no cracking or breakdown and all wires still flexible.
Every connection under the camcover cover was spot on. All fitted properly, alll leads making contact. Changed the plugs for new NGK and again checked all connections. Also checked the connections at the front for the cam sensor
Despite my best efforts under the bonnet it took an age to start (doing the crank / fire run for 4 sec /die routine ) and when it did start it very quickly re-established the 500-1200 idle routine running really badly.
Sun - well today it has made it to just about not starting, this is a blessing as I should now be able to cure it once and for all!
Symptoms
Crank it over and after a while (anything from 4 to 8/9 seconds) it will fire and run for 5 seconds max. (possibly fuel pressure dropping off?) - It cant be revved at this point or it will die instantly.
After firing the street is enveloped in a dirty cloud of unburnt fuel that you can really smell.
Car runs or not without the MAF with no difference
This year appears not to have an OVP relay and this is bourn out by the wirining diagrams I got with the car from when Ben built it. A lot of web wiring diagrams show the HFM system WITH an OVP. The actual original MB drawing Ben used to wire the car show no OVP relay.
I was leaning towards CKP sensor - (but I think this cut injectors if it were faulty ??) but the massive overfuelling makes me doubt this diagnosis./
Base control unit only uses 2 fuses when fitted to the 190- these are intact
A chat on the phone with Ben didnt reveal much other than he never had problems with it over many years - Having driven it back I can only agree that it was perfect.
I have a Multiplexer and Carsoft 7.4 arriving early next week anyway to help with any future problems (bought for turbo install) but I am just after any ideas to try before this arrives
If you got this far - thanks for reading
If you have an idea - even better !
Mark
(Wed) As above
Sat
Symptoms
Mark
