Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
I'd be tempted to open up the ECU and meter back to the output chip(s). There may only be one supplying all the injectors or there may be six.
Once you have the IC number it's just a case of buying it/them and a quick blast with the soldering iron.
The output devices will be cheap as they are simple switching devices.
5v fed from the main Lsi will switch the internal transistor on to short the injector return line to Gnd.
Given this issue I might be tempted to install a fuse on the 12v feed to the injectors.
