300ce-24 not starting.
smoothcoupe
WEST YORKSHIRE.
MERCEDES E55K-2001 AUDI S8-MERCEDES 300CE 24V SPORTLINE
My ce died at traffic lights 2day.. All of a sudden. The engine turns fine but won't start. I pulled one lead off and turn the engine over but there is nospark. I think itcould be the coil. Is this a sensible step. Any ideas.
more worrying it is the ignition module check the cables from and too it to the engine a coil.
it controls the start and spark, if u have spare (beg or borrow one) u could connect the other and try to start to see if that is the problem, u can get recondition yours if it the guilty party
If you are wondering what dinoy is refering to it looks something like this.
I had the same problem on an old w123 a long time ago and it was this thing! No warning, just bang, stopped working.....
Had the same problem on an old 300e-24 we used to have. Turned out to be a tiny crack in the distributor cap. Worth checking as easy to replace if a bit costly.
GP801 could be right, but I always found that a cracked or damp distributor will usually let you start the car but it won't rev or let you pull away, just stalls.
But definately worth a look........
Ours was running fine one minute then just refused to go at all.
Try a little WD40 in the dizzy, see if that helps things along a little, used to help my old Mini many moons ago on a cold damp morning!
Also, Smoothcoupe, is the E280 still for sale?
Hi mate. Someone has left a deposit on the e280 about 2 weeks ago and not returned. I will wait another week or so and then let you know, as this clown promised to return the next day. Cheers
Normally the case!!
I'll collect the same weekend :thumb: Does it have cruise?
Don`t tell me you sold yours?
Not at all, she is sat on the drive with 4 flat tyres needing a few bits and bobs. I could do with a load of little bits, buying the whole car from Smoothcoupe is a very good plan :thumb:
I'm trying to get it on the road ready for your next pre 95 meeting!! :bannana:
