Gedly
- Mar 6, 2010
- Location
- Newport
- 1985 C4 Corvette,1991 Camaro,Honda prelude,1988 mercedes 300ce
Just to say hello and can you help. I have recently bought my next project which is a 300ce 1988 for £132. She needs a little work but i do like the way she looks ish. At the moment im struggling,so please help if you can. When i got her i put the air idle valve back on and she ran fine:bannana: but since then the fuel pump is intermitant.(checked pump and is good) I have read the past posts and now think its the fuel pump relay faulty. The bloody thing will not come out??. Is it stuck ? The cover has come off as i tryed to pull it out and if i push the coil connector across the fuel pump runs. so seems like the ovp is giving power to the relay and fuse is ok?. Please help
