Last night I had a crazy failure of belt pulleys.
The viscous fan hub is getting noisy so I took it off to see if I could fix it (can't, but that's another story). Now, that's held on by the same 4 bolts that also hold the pressed-steel pulley on the water pump, as far as I can tell. However I had no reason to move the pulley so left that alone, and bolted the fan back on. The fan centre bit is still bolted solidly to the front of the pump, as is the pulley - and I'd driven over 100 miles yesterday (after looking at the fan on friday) with no issues bar the noisy fan hub.
However. Somehow, the pulley has gotten itself out of line, (water pump seems OK) and has fouled the crank pulley, deforming the groove that should have the alternator belt in it until the alternator belt has shredded. Thereafter, I got home by the good offices of the RAC so that means this year's membership was worth paying.
I've seen a couple of pulleys on eBay Germany. Are all M116 crank pulleys the same fitting, and can the pulley be got off without disturbing the centre crank bolt which holds the hub to which the pulley/vibration damper is bolted? It looks like it should be possible.
More info on how it managed to do this when I get it apart ...
