Red C220
I know little about SECs but had no idea the 560 put out as much as 300 bhp in stock form?
The Euro spec 560 motor was rated at 220kw or 295hp stock.
Having owned a 560 sec the 300hp it made standard was quite a handful. It really isn't going to handle much north of 380hp to 400hp without major modification and I'm just not sure it's the right car for so much power. It really is a cruiser and not a sports car.
Why tinker round with a M119 or M117 to get more power when the M113 5.5 already has 350bhp out of the box? In today's age, I would ditch the 25yr old CIS-E/distributor cap/rotor arm crap and go full standalone - far more tuneable and gives you the perfect foundation of further tuning down the line. Plus, the OP mentioned something modern, not period correctness.
let's do some comparisons...
Your going to need £2k+ worth of standalone ecu to get the m113 to run in the sec, your also going to need a transmission controller to run the gearbox, custom propshaft, custom throttle pedal. Then of course £1k+ for buying the m113 and box. So that's £4k gone to get the standard 350hp m113 running.
Whereas you can get a m119.960 for £500, which will work with the original gearbox and mounts, and can be made to run on the 560 management if desired for 325hp. That is a £3.5k saving!
Or throw a £1k standalone ecu on the later m119 to get 350ish hp, that's still 2.5k cheaper than the m113.
Your saying the cis-e and distributor controled ignition are crap, but the m119 didn't gain any hp when it changed to efi and coil on plug technology. So it obviously wasn't holding that engine back.
I can tell you that with the m119, 500hp can be done inside 10k. However I cant see the same happening with the m113.
As for the modern engine comment, the m113 has been around since 1999 so is hardly a modern engine.
The question is, would you want to drive a 500hp sec without doing something about the brakes and suspension? I would say your looking at 5k to make it handle and stop well enough to use that kind of power.
The m113 with all the parts you need to make 500hp fitted in a sec, is going to cost alot more than 10k. Infact Niks guess of 15k is cutting it fine.
If I was going to spend that sort of money, I think I'd fit an m275 v12 from a cl600 bi turbo for a standard 500+hp without mods. You can always fit larger turbo's and intercoolers if you want more power.
I hear what you are saying here. I realise the chassis will have limitations but I am not expecting to make something that will handle like a sports car. I want a cruiser that I can have fun with the odd time. The reason i want to do the mods is the satisfy my hunger for a challenging project. A simple engine swap wouldn't be taxing enough. I put 450hp into a 50 year old Mustang after upgrading all components with a good deal of custom work to make brake servos work with steering rack and exhaust manifolds, etc so the thought of some mods does not put me off. Another reason i would like to achieve 500hp+ is for nothing more than a bit of fun. I know some of guys are going to be thinking just buy an E55k/CL55k and drive the thing but my new project needs to built on a chassis 30 years old to avoid €2k in road tax which i wouldn't mind for a daily driver but not for a weekend toy.
Using my very complex man maths calculator....
I'll expand a little.
It's not just handling, you'll need major structural modifications to handle that power, basically a full roll cage.
The SEC is a pillarless coupe and the standard 560 motor twists the bodyshell as it is. A 500 hp SEC is going to be a bare shell build, effectively a road going racing car.
The lack of B posts on the shell design really does create a structural issue.
T
You mention about £4.5k to get the M113 running in a SEC for 350bhp but as above would the M113k be a lot different?
Can anyone confirm if there is any difference in the M119,M275 and M113 in RHD and LHD drive cars. i.e if i buy an engine from a LHD car will it work in a RHD without modification. The old yank V8 was the same except some mods to the exhaust headers.
Gotta be a V12, preferably M275 to be a bit more unique.
The W124 cabrio had extra chassis reinforcement. I've heard of the same strengthening bars being used on track day 190s and 124s.
I'm sure adding a bit of rigidity to the chassis on a 126 won't be the deal breaker for you.
If you really do need more power then has to be an early (1990/1991) M119 with the older style fuel injection system.
