Pcn1
PCN1 & Mark you need to check your facts before offering advice there may not always be someone around to provide correct info and it may be costly to others on here.
When I posted I said "I may be wrong" knowing I wasn't, but at least it lets others know there may be some doubt!!
The only slight miss -understanding I see may come from checking the oil temp with a thermocouple which I had attched to the dipstck, engine off at this point so the thermo couple (which is a just a very thin wire) wasnt caught up in the box and causing damage. When I was satisfied the temp was correct, then yes its engine back on, move the gear stick etc and then insert your level stick. Aploiges to the OP if there was any confusion.
As I mentioned, plenty of videos on youtube for the OP to watch first.
