Hello, new here. I have a W211 with the 722.6 trans and it started jerking when in 3rd gear when the weather got cold. It does it only when cold and only in 3rd gear. Shifts between gears are ok but when in 3rd it starts jerking as if you haven't given enough throttle input when releasing the clutch on a manual trans car. If it was the torque converter or the lock up solenoid it should be doing it at any gear, right? Any suggestions what could that be, and if this can be diagnosed with the proper MB diagnostic software are welcome.
