95 W124 E280 estate light problem
darreningram
Have developed a small light problem recently- when the boot is open there is no problem- as I close the boot the rear reg number lights come on as well as front dashboard and heating control/ electric windows illumination- cannot turn then off unless I open the boot- subsequently on leaving the car after switching it off and removing keys the lights remain on and the lights on warning buzzer buzzes- a minor frustration but the flat battery is a right pain!
Thanks in advance
Definitely tailgate wires. There are looms on booth sides
The easiest way to replace them is to do them one at a time. A good yank on each wire up inside the headlining will show you which need doing - the broken ones will pull right out
Nick Froome
Thanks for the help, will strip the trim down and get a look- thought that might be the problem
