Teego
I just discovered Essar @£1.579
Essay fuel stations. They’re not a common sight on the roads.I filled up with Tesco Momentum 99 last night at 146.9p/litre yesterday, where sells Essar?
Here's where they are. None near me.
Never sure whether one 99 RON is better or worse than another, additives, etc. Hard to know.
Indeed, there is more to fuel formulation than the octane number(s)…Here's where they are. None near me.
Advised by who? That would be the obvious questionI think different tuners and different engines perform better or at least the tuner prefers a particular fuel. In the VAG scene and having mapped some Audi/VW last being a golf R the tuner the suggested they ran better on Tesco Momentum. I had an A45 before my current E63 and was advised to run the A45 on VPower as the burn cycle is longer and the engine performs better on it.
Sure is, and you can spend many hours on YT learning about it.Indeed, there is more to fuel formulation than the octane number(s)…
I remember our E46 M3 would “pink” on 95 Ron (super unleaded wasn’t available as much back in 2003) However when it did get Super, it would literally change its noise, throttle response and economy. Same went for my wife’s 330i in the same days (back when BMWs were nice)There have been many independent tests of the different fuel types....lots online and YouTube etc. yet to see one where the V Power or other expensive option had been proven to be any "better" in any measurable way over the cheaper brands....as long as the Ron (95, 97, 99 etc) is the same than they are basically the same fuel.....even then the differences are often not great as the fuels often test higher RON that claimed as the RON rating in this country is the MINIMUM RON of that fuel....same as the Ethanol E number.....Esso fuel sold at E% is mostly E0 Don't forget the base fuel is often EXACTLY the same fuel loaded from the same silo as all the other brands (seem different tankers queing up myself at Southampton fuel depot).....the adaptive packs are added AFTER the fuel in the the tanker.....and if you see how much they add, its at homeopathic quantities. I'm sure lots of the perceived improvement people say they feel is nothing more than a placebo....after all who would want to day they buy expensive fuel for no gain!!!? Those who put 98 or 99 in a car designed for optimum performance on 95 (which is most UK non performance cars.....most AMG cars etc specify 98/99 fuels)) are even more gullible.....they just cant advance the ignition enough to take advantage of the higher octane. Don't get me started on the supposedly high performance super diesels.....complete rip off! As long as you are happy with what you buy that's all that matters.
Pretty good video about the differing "premium" fuels and their dyno results...
Yes you are correct hence I wrote not every station had super back then so a little 95 was used in emergencies.E46 M3s are supposed to run on 97 plus....so would not be happy on 95.
Shell VPower Diesel used to be GTL - not sure whether it still is - and that has numerous benefits over regular diesel fuel.Don't get me started on the supposedly high performance super diesels.....complete rip off! As long as you are happy with what you buy that's all that matters.
As you say Shell V-Power Diesel did and maybe still does include GTL (gas to liquid), but it’s never been 100% GTL.Shell VPower Diesel used to be GTL - not sure whether it still is - and that has numerous benefits over regular diesel fuel.
I found it made a noticeable difference to the sound of my car. It could have been placebo, but other people commented that it seemed to be running more smoothly and quietly too, and they didn’t know I was using a different fuel. Not scientific, but not owners/buyer unconscious via either.
It’s been quite a while since I owned a diese though so I really could comment on current or recent formulations.
