sspeed
- Apr 19, 2009
- 2006 CLK320 CDi
At the risk of an outcry of heresy from y'all I am going to recommend a device I have used for many years on many different cars I have owned.
It is a suction device for removing oil (and other fluids) from engines. It was originally developed for marine engines as they don’t have an accessible sump plug (obviously).
The device I am talking of is a “PELA” oil extractor..
The version I use on my C270 CDI is here:
I cannot recommend the following product highly enough.. Its the best labor saving device I have ever bought..
http://www.cdet.co.uk/catalogue/prod...roductid=PL650
I change my engine oil about every 6 / 7000 miles (half the manufacturers recommended mileage). I go for a drive to warm up the engine . . . Wait 10 minutes for the oil to settle, then push the narrow tube (you are supplied with 2 different diameter tubes) down the dipstick tube all the way till you feel it hit the sump floor..
You then give about 8 or 10 strokes of the devices plunger and sit back for about 5 or 6 minutes..
My particular suction device holds 6 liters so I stop it at about 4 liters and empty it into a Jerry can (holds 20 liters)..Then I re-attach the tube to the suction device and pump the plunger...Lo and behold you will remove another 2 - 2.5 liters of oil (depending on the level you had in the sump).
There is one more big advantage you get from using this device.. When I have removed the oil filter there is a pool of dirty oil in the bottom of the oil filter housing. I use the end of the tube to literally vacuum this out.. This half cupful of oil would NOT normally be removed.
I once chatted to a BMW service manager off the record about this device cos I used to own a BMW 330D which I did intermediate oil/filter changes on.. He said "They are brilliant...Between you and I we use a suction device when we service our cars".. Yes you read this correctly...BMW use this method. If its good enough for them then I am more than happy to use it for my car.
He then went on to say that “This Long life servicing is boll**ks.. It originated because each manufacturer wanted to make its own brand appealing to fleet buyers.. If brand A has a service at 10k but brand B has a service at 14k then which brand do you think the fleet buyer will go for”?
I originally posted this on the BMW Forum and also “The other side” and when I sung this devices praise, I got lots of negativity about " How can you be sure it gets all the oil out" etc, etc.
I had to laugh because this criticism was from owners that were happy to trust the manufacturers recommendation of leaving oil in the engine for 15,000 miles.. As far as I am concerned, even if I only remove 95% but I change it twice as often as recommended then I am on the right track.
On the subject of “being sure it removes all the oil” there is a guy on “The other side” that put his C270 onto a 4 wheel lift.. Drained the oil with this suction device and then for devilment removed the sump plug… “Not a drop came out” is what he says..
The reason I use it is obvious.. I don’t have access to a 4 wheel lift and driving the car up onto ramps would mean errrr its not level. More importantly it makes a tedious and messy job very easy and clean to do.
As stated earlier I do an intermediate Oil / Filter change and then have an official service without telling the garages that I molly coddle my engine.
Lastly I don't work for PELA and have nothing am in no way connected with this company..
I just recognize a damned good product that for once does what it says on the tin !!
Regards,
Simon
Regards,
Simon
