- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
My guess is that it's a 7g+ 'box which uses (and must be filled with) a different fluid to the 7g 'box.
Bingo.The fluid was apparently red but should have been green or blue
The 7g+ fluid is blue, the 7g fluid is red. Graeme ( @grober ) makes the valid point that this is for the MB-branded fluids, but if the oil change was carried out at an MB dealer then that would be most likely true.
As you know, there has been confusion for years amongst MB dealers as to the transmission oil change interval because it kept changing and the 7g+ 'box requiring different fluid added to that confusion. While it's correct that the 7g+ 'box has a first fluid change at 77,500 miles, the 7g 'box was much sooner - around 37k miles from memory - so it's very likely that someone thought, "W204, 7g 'box, 37k miles, let's change the fluid" which would explain why there is the incorrect, red, fluid in the 'box now. A used car bought in 2015 with that sort of mileage would likely have been built around the changeover date from the 7g to 7g+ 'box (2011/2012), so is a prime candidate to get confused over.Also... the 7g+ box requires the Automatic Transmission Fluid (ATF) to be changed every 5 years or 77,500 miles.
So if the approved used car you bought was under 5 years old or had less than 77,500 miles when you bought it, then it is unlikely that the ATF had ever been changed before you bought it.
Which is why I wouldn't trust the dealer's diagnosis blaming the 'wrong colour' ATF.
Assuming that the Digital Service Record exists and indicates that a fluid change was done, it should be possible to interrogate the dealer's service record to find out what fluid was booked to the job - assuming that they haven't (conveniently) "lost it", of course.
