I think the figures say it all. You had an average speed of only 19 mph so the traffic must have been awful and you must hardly ever have been in top gear. My brother has an A160cdi and has averaged over 60 mpg since new and that is a pre facelift, pre 'blue efficiency' model.I've got one of these as a courtesy car at the moment. I've been watching the mpg with interest. Bearing in mind this is supposed to be fuel efficient, and even has the (irritating to me) stop/start facility, I have to say the fuel consumption is pretty woeful. I took this pic this morning, after using it for two days' commute:
31mpg? Granted, the car is brand new, so is pretty tight, but the Mitsi Colt that we normally use for the commute returns 45mpg+ on the same journey, even my 320 manages mid twenties. Is this 'Blue Efficiency' all marketing hype?
It also has one of the hardest driver's seats I've ever sat on! After only a few miles, I'm getting a 'numb bum', for want of a better way of putting it, and being a base model, the seat base has no tilt adjustment to help matters.
Its utter nonsense if manufacturers start to make cars designed to score artificially highly on some sort of theoretical emissions test without consideration to actual driver requirements or real world figures.
I drove a new MINI Cooper Clubman D the other day......................................
Swap the tyres from the 17" to 15" skinnies and I bet you could get nearer 80 mpg once the engine has been run in.
Only if you forget to fit tyres!...the smaller diameter wheels would mean the engine would need to rev higher to maintain similar speeds.
I found the seats in the A class excellent. But if I had sat for nearly two hours to do only 35 miles the seats would have seemed very hard indeed and I would have been very fidgety! Like watching a bad movie -the seats always seem hard. We did over 2,000 miles in a fortnight's holiday in France and down to Spain and neither of us had any problems with the seats.
Even in the A180cdi I regularly averaged over 45 mpg and over 50 mpg on a good run.
No. You can see from the MB website that larger wheels with lower profile tyres (to keep the same rolling radius) have higfher CO2 emissions and of course worse fuel economy. They also aquaplane more easily, give a worse ride, wear out faster and cost more. The silliest fashion for years IMO.I thought that larger diameter and therefore lower profile tyres (same rolling radius) gave better efficiency, due to less side wall movement.
They aren't normally the same width. They are wider (presumably to get a similar volume of air in them for loading and resistance to bumps etc). Narrower tyres cut into water (or mud) as a sharp knife would more easily than a blunt one, while wide ones float like a boat. Several motoring journal tests have shown the aquaplaning problem. Any 4x4 owner who goes seriously off road knows that low profile tyres are useless. The worse ride is largely I think due to the much stiffer walls needed on tyres where the wall depth is very shallow. If not you would keep banging the alloy. IMO motorists are forgetting what tyres are for. And fashion is taking cars that engineers spent years perfecting the ride for 16 inch wheels and ruining them with 17/18 or even bigger wheels -all just to look like a kid in a Nova.Why would a lower profile tyre aquaplane or wear out faster than a 'normal' equivalent, assuming the same width and rolling radius? I'd be genuinely interested in any proof of this.
Alloy wheels used to be a luxury and exclusive. Now the only exclusive thing would be to insist on standard sized steel wheels!![]()
What about the faster wear rate you mentioned?
Anyhow, many modern cars are designed to run on these lower profile tyres that they come with, so surely suspension rates etc will be specified for this? Our Colt has 16" wheels with 205/45/16 tyres from the factory, and it's only a little runabout. I'm just about to replace the front tyres at 25k miles, not a terrible wear rate.
Faster wear rates because the low peofile tyres generally have softer rubber amongst other factors..
Suspension alterations cannot make up for more unspring weight.
It's not diesel, it's petrol. It's pretty gutless too, our 1.1 Colt feels as quick, and that only has 74bhp!
there must be something wrong with it. Our petrol engined W169 can easily get over 40 mpg, so the diesel should better that.
