Fastcar155
Hi, not on my car.Thats not correct. 1 touch down works.
Must be broke then. Works on mine c207. Just not up.Hi, not on my car.
Thanks guys.
Puzzling... why would they have double click switches if one-shot closing was never intended to operate?
Let you know how I get on at the dealers ...
Yeah but...You have two stage switches on the rears to facilitate the one-touch opening. First click is partial opening second click is one-touch full opening.
Yeah but...
Why have switches for the rear windows that have a definite two clicks for both up and down, if the second click was never intended to do anything? Doesn't make sense!
The switch in the centre that operates all four windows has two clicks down, but only one click for up, so obviously that was never designed to have one touch closing. So why aren't the window switches on the drivers door and in the rear designed with only one click for up?
Hi , different year models have different operations.Must be broke then. Works on mine c207. Just not up.
Yeah , of course .Hi , different year models have different operations.
Thats weird, on mine is doesn't make any difference, ignition on or engine running. the rears still don't have one touch up.Hi , with my C207 the windows with the ignition turn on the rear windows operate with on manual basis both up and down.
However , with the engine running the rear windows automatically go down but require holding the switch to close windows.
Make your mind upHi , with my C207 the windows with the ignition turn on the rear windows operate with on manual basis both up and down.
Hi , well I thought members were meant to help each other with passing on knowledge.Make your mind up
Doubt it ever did . No one else's did or has.Thanks for the info ...
I'm waiting for a response from Mercedes UK customer service about this. Hopefully I'll get a clear unambiguous answer about these damn windows!
Although, I'll probably not believe it if they tell me rear one-shot up has never worked... because I know it did!
Beggars belief . !!Hi , well I thought members were meant to help each other with passing on knowledge.
I found this out yesterday by chance !
Yes its gone on too long now, we are getting bored.Beggars belief . !!
Beggars belief . !!
Hi, I too have a 2016 A207, I can confirm you that you are 100% correct. My A207 rear windows do close with the one shot operation. I think you should consult a renowned car mechanic to get it done. Hope this helps.
