mat8n
Banned
- Dec 30, 2013
- Location
- Stokesley....ish
- Sl63,honda crf450x, BMW x3, vespa lx50v, Honda goldwing in bits!
Ok, on my '03 sl350 r230 my ABC visit workshop light keeps coming on in the light blue.
I've just had a new pump fitted as the garage thought it was that as it was knocking(I can't take it back just yet as I'm away working), there was no leaks anywhere and the shocks are all good.
Since I've had it back I noticed the light only comes on occasionally and more often than not its when you put the roof up/down?
Again just recently both my wife and I have noticed that when you sit in it idling for a few minutes it starts to raise/lower itself on the hydraulic suspension!! As if it's trying to find its level. Then 'maybe' the ABC light will come on?
If I switch the ignition off it has 1 malfunction and if I let the electronics close down, when I switch it back on it has zero malfunctions.
I'm guessing it's a sensor or a short?
Anyone else had similar symptoms or knowledge about this that I can pass on to my specialist when I get home?
Thanks in advance
Matt
Thanks in advance
Matt
