gromit
ABS Fault appears on dash when turning corners and if I turn corners at a higher speed (30) then the speedo stops and starts!!! HELP. Had the codes read today and the codes said faulty speed and wheels sensor on all four wheels!? When speedo stops, the gearbox won't change up or down.
Fault doesn't happen when driving straight or turning slowly. Only happens when car is leaning whilst cornering. Hope this makes sense to someone.
ANY IDEAS??????
Car is a 2002 w208 clk200k.
ANY IDEAS??????
