Juan B
Hello everyone.
Yesterday I removed the front ABS sensors of my car, for cleaning. They were not very dirty, but yes a little.
I have not cleaned the teeth of the hub, because I have not known how do it. I thouth in a brake cleaner through the hole of the ABS sensor and with the help of a brush. I don't know if it's a good idea.
The problem is that when I turn on the engine, the ABS light goes out (this is normal), but when the car starts to move, up of about 5 km/h, I hear how the ABS pump is turned on (I can hear a "brrrrrrr" noise) for about two seconds, and two secons later stops for start on again for another two seconds. If you press the brake pedal (when I hear the noise), I notice the vibration in the foot and the brake is poor, until the car is almost stopped. I don't like this, because when you start to drive, the brake does not respond to pressure from the brake pedal.
After I've driven about 50-100 meters, it works fine, until the car is stopped for a few days.
Once, after driving about 5 km, ABS light turned on and it not turn off until the I turned off the engine and turned on again.
I know there are another sensor for the rear wheels, located in the transmission, but not where it is located exactly. Is it easy to remove for cleaning? Does anyone have a picture to see where you are?
I wanted to measure the resistance of the front sensors, but have not found the connectors. I think that the driver side one is near of the fuse box, isn't it?. There are two connectors, one is flat and the other is round. What is the plug of the ABS sensor?
Where is the ABS sensor connector, on the passenger side?
Thanks in advance.
Thanks in advance.
