smudger92
Hi Everyone,
I'm hoping someone may be able to point me in the right direction with an issue that started yesterday and is progressively getting worse.
My apologies in advance if it appears I am rambling, or not giving the right info.
Anyway, Here goes..... I own a 2004 CLK270 which I love. I have had it for nearly a year now and the only issues i have suffered are a couple of headlamp bulbs.
My problem started yesterday when i was driving across the M62 from Manchester to Huddersfield. I engaged cruise control (CC) and sat back as i always do to let the car do the work.
The cruise control worked fine but it felt as though the car was accelerating and slowing down constantly. I have never had this experience before, so i disengaged CC and tried it without. Didn't appear to be any problems when disengaged. Put it back onto CC and same happened.
Same thing happened on the way back, i even tried different speeds to see if that was an indicator of the problem. But no difference.
Today, I had to drive from Manchester to Poole as that is where i am working at present and the same thing was happening again. However, i have felt and noticed other things now.
If i accelerate in 5th or 6th it feels as though there is a slight back pressure from the accelerator pedal and then she accelerates.
I am sure i was noticing a small puff of smoke from the exhaust as well. However, i may be paranoid, but am pretty sure there was something going on.
As i came off the motorway and onto a dual carriage way i changed down to third to overtake someone and all that happened was that the engine revved the B**^^*ks off itself, i changed back up to 4th and she accelerated. However not at a great pace.
I found that 3rd gear acceleration would work if i was changing up as normal but all acceleration just seemed and felt so slow.
I am expecting this to cost me an arm and a leg to sort out, (ever the pessimist), but am hoping it isn't. I am due a "B" Servicing in 700 miles as well. Not sure if that has any rellevance.
As i am working near to Poole and Bournemouth, any local recommended garages would be greta.
Am hoping that one of you guy's has come across this before and can help as I don't have clue.
Thanks for reading
Dave
Thanks for reading
Dave
