Adding BT to an early 211
Smiley
I am trying to figure out what I need to add bluetooth to my 2003 211 with a factory option Nokia cradle in the armrest option 382.
The part number showing on the handset cradle is 211 820 1451
I think that my only option is an early Viseeo MB1000/3000 which has the same form as the Nokia 6210/6310 handset - but any advice on what will or will not definitely work is appreciated.
Shed loads of viseo units on eBay . At least if it don't work you can return it. The sellers should know what's what and your requirements. 👍
As my W211 does not have the Aux socket I decided to by the Mr12Volt Bluetooth USB AUX adapter from eBay. I have fitted it and it sounds much better than the FM transmitter that was powered by the cigarette lighter. It's all hidden where the 6 disc CD changer used to be which means that I still have the original look.
