D
Deleted member 91561
Guest
Hi All,
I'm still quite new to the forum, and haven't made too many posts, although I have been doing a lot of research, searching and googling in the background in order to put together an initial spec for tuning my C63.
Just to give you an overview on the car, I have a 2013 Performance Pack C63, with 487bhp from factory and around 27,000 miles, which has now been Eurocharged making 516.2bhp at the time.
My main aim is to add a bit more power (Hopefully around 750bhp), improve the handing and responsiveness, while trying maintain the reliability of the car as much as possible. (Don't fancy blowing a transmission)
Having spoken with Acid (Who let me drive his car, thanks for that), Eurocharged, Lee and a few of the other people around the scene, I thought it would be a good time to start a thread posting my ideas so I can get a further understanding of the modifications, and what may be the best options out there.
So far I've kind of decided on the below:
Weistec Stage 2 or Stage 3 Supercharger Kit
IPE Long Tube Headers
IPE Cat Back Exhaust System
Quaife LSD
Valvebody/TCU Upgrade
KW DDC Coilovers
My main decision I feel is deciding between Stage 2 and Stage 3, realistically at Stage 2 I guess you're looking at around 720bhp, but with Stage 3 on a low boost setting and with a larger pulley closer to Acids 87mm I should be able to get close to 750bhp. Although then we could be on the boundary of something breaking.
Moving forward I feel the benefit of going Stage 3 would be if I wanted to add more power. Once I could afford to look at the internals and transmission further, with Stage 3 it would only mean a pulley change to drive some more power from the charger instead of upgrading from a 2.3l to a 3l charger.
What is the maximum power you can safely run a PP C63? (I've heard around 750-800bhp)
It would be good to hear everyone's thoughts, and whether there's anything you'd change or add etc......
Quaife LSD
KW DDC Coilovers
