After 16 years hibernating...
New tyres are not "advisable" they are a must. Tyres have a shelf life and those will be well past it.
Fantastic find & story.
Looking forward to more pics and info as the recommissioning commences.
Agreed about new tyres - a must!
That looks in lovely condition .
There was no option of electric sunroof on the estates ( nowhere to put the motor ) .
The rear end looks to be sitting a tad low ? You can adjust the link between the rear anti roll bar and the valve for the self levelling suspension to correct this - it may even have stuck after all this time .
New tyres will certainly be advisable , but you are probably running 185 or 195/70 x 14 , I think H rated on the 230 , from memory , and these are not so easy to source nowadays in a decent brand .
If you have not already done so , also change all fluids : engine oil , coolant , ATF , PAS , self levelling ( MB ZHM mineral oil ) , brake fluid , diff oil . Also check all coolant hoses and drive belts since they may well have perished after standing for so long .
I'd also look at flexible brake hoses and possibly even getting the calipers overhauled after the car has been lying for so long - I once had a catastrophic brake failure after starting to use a car which had been standing for a similar length of time - this was my Ponton with drum brakes and a seal in one of the wheel cylinders just 'went' - thankfully , I was slowing down for traffic lights and almost managed to stop by pulling on the handbrake before 'nudging' the back of the Rolls-Royce in front ! Could so easily have been expensive but no damage to either vehicle and was complimented on my car by the gent in the RR :D
Since that incident , I have been paranoid about brakes and always go over the full system carefully on any car I buy .
Good luck with your car .
You should still be able to order the Haynes manual on the W123 which has a lot of useful info .
Your new best friend is Mark Cosovich , the UK's leading W123 specialist - tel 01792 846888 or 07714 089936 . Mark restores these cars and can even source some parts no longer available from MB !
Thanks. I thought the rear looked a bit low, and thought it might come up a bit after getting it running, but not so far. The previous owner said it was always like that (of course his memory might not be 100%), but the wear pattern to the inside of the rear tyres suggests to me it has been running like that? It's a shame Michelin don't still make the XVS - you're right, they're 195/70 HR 14, and I haven't found a modern equivalent yet.
So far the engine and gearbox oil have been changed (along with the filters) - the ATF was a lovely red, with no silt or anything in the pan, and it is nice to be able to drain the torque converter: something I've never come across with old American stuff. Also coolant and brake fluid done, but haven't done anything other than check the levels of the P/S and leveling reservoir. I've been running my old 518i daily for the last few weeks on the tank of 16-year-old unleaded I syphoned out :)
I have the Brooklands W123 manual which has been useful, but I was under the impression the Haynes one was for the oil-burners, not petrol engines?
Oh, and Ironside was one of my favourite TV programs when I was a kid!
I don't know if you have tried Vintage Tyres : 01590 612261. The advertise in the Mercedes Benz Club Gazette.
The power steering just runs on standard ATF , same as the gearbox . The SLS uses the MB ZHM mineral oil which is about a tenner a litre !
When you have a look under the back end you will see the link from the anti roll bar up to the valve - there is an adjustment in the link to set the ride height . Sometimes the valve sticks and the bracket slips on the ARB , or one of the ball and socket joints comes undone . If you get the car on a ramp so it can't collapse on top of you , you can unclip one end of the link and operate the valve ( with engine running ) until the car sits at a level you are happy with ( Mark C could probably give you a measurement for the correct height ) . I will try to find some brochure pics , or a pic of my old 280TE for reference ( traded in for a W124 300TE some 13 or so years ago ) , not without some regret , but it was getting on with 200K to its credit .
The Haynes manual does cover petrol models , including 200TE , 230TE and 280TE .
Beautiful car you have there.
I'm normally not a big fan of red cars but for reason W123's (and the contemporary SL's) just look right in red to me.
Thanks for posting it on the site and welcome.
Thanks again for the tips, and the compliments.
I was offered the car as I mentioned I wanted another estate car, and they knew that I liked "old stuff". For some reason I had it in my mind that it was going to be white, and was in two minds whether to go and have a look at it - it was more money than I would normally be paying for a daily driver as I tend to make them earn their keep.
Anyway, it wasn't far to go, so I arrived - the garage door was opened and...it was RED!
It has left me in a bit of a quandary as it is really too nice to be (ab)used daily.
As requested, more pics, mainly of the interior for now (before I took the rear bumper off to polish it up).
Only able to upload three pics at a time, so here are the others for now, including one of the front (yes, the bonnet star was busted off in a car park once upon a time
Other than a dead (bone dry) battery, the engine bay was pretty good once I'd removed the store of sunflower seeds from inside the air cleaner! It looks a little grubby, but that's mainly due to the waxy coating liberally sprayed around under there.
As the Welsh would say, 'Tidy' :thumb:
Very nice indeed .
It has exactly the same interior trim as my old 280TE , except my car had Champagne Gold metallic paintwork , and was only about 5 years old when I bought it so in similar condition , but not by the time I ran the mileage up to 200K !
That is an absolute corker!
That's a nice looking car,I like the orthopedic seats. Something you don't see on US cars often.
Thanks, the interior is nice - and still has some of that new-car plastic smell. allabasi, you've lost me on the orthopedic seats bit?
Haynes Manuals seem to cover everything BUT a W123 230: there appears to be one for '76-'85 W123 diesels, one for '76-'83 250 & 280 W123s (I hadn't seen this one before), one for '77-'81 USA 280 W123-models, and then it goes to '85-'93 W123 petrol and diesels. Engine apart, I guess the second one would be the most useful, although the diesel one mentions estates?
