topgun1978
Hi all..hoping someone can help with the following issue I have with my 1999 ML320 W163...
SRS light is constantly on and got someone to read the fault codes which showed that the Airbag ECU is malfunctioning (as well as passenger seat sensor) and we couldn`t erase the fault. So concluded that it needs replacing...
I have managed to source a second hand ecu but wanted to ask you guys firstly:
1) where is the airbag ecu located
2) Is there is a DIY anywhere for how to remove the parts, trim and replace? Or can anyone help enlighten me?!!!
Thanks all for any help you can provide...
