Ross_lewis
- Jul 9, 2012
- W203 c220cdi
Hi guys, new to the forum and love my c220 already! Only problem I'm having is a not working Aircon system,
The compressor turns constantly when the engine is running, the led inside the 'Aircon off' switch works as it should but I can't hear the compressor clicking when the switch is operated. I have pressed the charge port valves and both have pressure behind them. I have put a voltmeter to earth and onto the single wire connector that joins on top of the compressor and have no voltage. All fuses are ok but I'm unsure if there is a relay or something simple that I'm missing,
Has anybody had a similar symptom and could point me in the right direction?
Thanks in advance![Thumb :thumb: :thumb:](/styles/mbclub/smilies/thumb.gif)
Ross
Thanks in advance
Ross
