Ok will try the a/c control unit bit after I ascertain all ok with the other parts to check. DrNick how can I diagnose if I have a problem with the duovalve? The fans blows external air in and is working well, at all speeds on the dial. Trying to get to the cabin temperature sensor, shining up I can see the round hole with something thin and dusty coming down in the middle of it.
I have also been trying to think back if warmer air has bbeen blowing through the vents relative to outside air. Read somewhere that could be possible thus reducing the efficiency of the a/c and maybe in my case crippling it or the duovalve? Thhinking back, whilst in UK in 2002 during winter the heater did blow hotter air than normal sometimes at prolonged periods even when the dial was turned to the white areas but it doesnt seem to happen now - perhaps back then I just got the car so wasn't familiar with MB heaters requiring very small adjustments for heating.
Is there a accurate test I can perform to check heaters are operating as specified?
Btw where does the cabin air vents draw air from, where is the mouth?
