Airmatic problem!! again
owensmith
SE London
SL500, S500,
Hi Yesterday i removed the pump to repair it as the the back of it came of and it was extremely loud fine it worked but still louder then normal guess it was on its way out? Today it stop workin as i adjusted the dampening settings is it ok to drive around with it not working the suspension is at a normal hieght has not dropped for the last four hours! im not bothered if it does not work just dont want the car dropping?
My advice to you is to get the car checked out asap.
You may think its ok but will your car respond to you in a case of sudden braking ???
Dont risk it, get it LOOKED AT.
Checked car today connection was loose!:confused: so imback on the road again now just the front brakes to do oh what fun!:bannana:
